My Vegas went nuts... After i remove all the audio from the project it still gets rendered, even if every audio timeline is removed. Restarting Vegas doesnt help. How can i fix this?
Results 1 to 10 of 10
Is it there when you play back the timeline?
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Obviously you are doing something wrong.........
Depending on export format you use, you can disable the audio on export. Otherwise you'll have to demux the output clip and re-mux without the audio.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Im doing the exact same thing like for the past hundred videos ive rendered. It went nuts today.
It behaves like if it memorized that the audio is still on the timeline, when it comes to render, but there is no audio.
As for my project, i actually want audio there, just different track. When i put the new track, previously removing the old one, both of these tracks are overlapping eachother after render in final video. -
Contact Sony support and submit your bug report.
http://www.sonycreativesoftware.com/support/Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
You probably have hidden tracks in your timeline. "C" is the default keyboard command to show/hide them.
And you should not be "doing the same thing every time". Render a movie with Video+NOaudio! Just customize your template. Done - Even if you had audio tracks, they wouldn't render.
Scott -
Yeah, exactly. Uncheck the audio rendering in the template. Then save to a new template.
